Battery?
Old Jan 29, 2003 | 12:34 PM
DAC350's Avatar
Battery?
I go to start my car and the starter cranks for a split second and then everything stops. No lights, nothing. So I'm thinking dead battery. I take off the positive terminal, and then reconnect it and the car starts right up. There is no corrosion and the terminal was on there nice and tight. Is there something else that is slowly "dying" and causing my car to get no power at all? The battery had a full charge when this happened. Thanks.
Old Jan 29, 2003 | 01:17 PM
'94 Bad A Z28's Avatar
Re: Battery?
You said you took it off, put it back on and it started right up... Also that it had a full charge when this happened... Maybe it's just a lose connection?
Old Jan 29, 2003 | 03:23 PM
n2ceptor's Avatar
Did you notice if the security light was blinkng??? I know on mine sometimes when the key doesnt register it does that ... Hasnt done it in a while though....knock on wood...
93Z Will
Old Jan 29, 2003 | 04:59 PM
BUBBA's Avatar
No 1. battery problem is a bad battery, whether it is poor quality or past its prime.
Be sure to check the terminal itself. It may be clean and your connections tight, but I have seen new batteries (cheap type) with a terminal that actually turns inside the case (not a good thing). Check it out. jmho
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
weedog
Aug 15, 2015 08:23 PM
