Rebuilding T56 Everything needed?
Old Jan 29, 2003 | 04:13 AM
SVT Killer LV's Avatar
I am going with the
-T56 Synchro kit from D&D
-Steel Shift Fork from D&D
Is there anything else I should give to the tranny shop??
Old Jan 29, 2003 | 10:38 AM
Acct 23749's Avatar
I am planning on doing mine soon too, i was gunna get new blocker rings and bearing/races set
Old Jan 29, 2003 | 11:23 AM
thermwood1's Avatar
It depends on what you use the tranny for. Also, was it just the synchros went bad, or did you break something in the tranny for the rebuild? The reason i ask is because there are some other parts for the T-56 to make it better. Basically the T-56 used in the Viper trannys is similar to ours (if not the same). The output shaft is larger. But there are parts available that are the same ones used on the Viper GTS-R racers. So, really it depends on how much money you want to spend and what you do with the car. The best person for more info on these parts is John Donato @ Donato Engineering. I have spoken with him a few times and he seems very knowledgeable and helpful. He can steer you in the right direction. You can reach him at 248-676-8554 or donatoeng@aol.com. Good luck.
Old Jan 29, 2003 | 12:07 PM
97_TA_WS6's Avatar
I highly recommend contacting John Donato he was great always answered my emails quick. I also purchased the Carbon Kevlar synchros from the Viper GTS-R T-56 for $140.00 he sells all the stuff you want even Carbon Kevlar pads. Talk to him he will let you know what you need.
Adam 1997 Trans Am WS6 M6 has Borla cat back,LT4 knock module,subframes,Hypertech PP+,Hypertech 160 Thermostat,Air foil,Mac Pulley,K&N filter,B&M Ripper Shifter,MSD 8.5MM wires,Energy Suspension Trans mount & Torque Mount,1LE Driveshaft,MBA Silver Shift **** with WS6 ingraved on it,SLP 21mm Rear Sway bar,Viper GTS-R Carbon Kevlar syncros in a rebuilt T-56, Throttle Body Bypass and SLP pressure plate/clutch.
Dallas, TX
Old Jan 29, 2003 | 02:10 PM
FRDEATR's Avatar
Yeah, get the carbon syncros and the stell 3-4 shift fork. I did and my tranny is flawless (so far)
Brian
Old Jan 31, 2003 | 04:08 AM
140 that is CHEAP.. DD Performance wants 229 for the synchro kit for those prices can not beat it.. wow
Old Jan 31, 2003 | 04:27 AM
Punisha69's Avatar
thanks for making this post... i'm also doing mine..
when are you gonna start yours? and what are your symptomes?
mine doesn't want to stay in 3rd much.. and is making funny noises....
i don't like it...
how much do you think you'll spend? and how easy/hard do you think its gonna be?
thanks
PS> can somen please list ALL the parts i'd need? should i be replacing gears ? or only if they're bad!?!
Old Jan 31, 2003 | 09:39 AM
wont stay in third whatesoever
Old Jan 31, 2003 | 11:08 AM
96SS#1156's Avatar
How do I get in touch with D&D?
Old Jan 31, 2003 | 11:15 AM
Acct 23749's Avatar
http://www.ddperformance.com/index2.htm
Old Jan 31, 2003 | 12:47 PM
Punisha69's Avatar
dude
same story
ok.. let me know when you do this k?
mind emailing me?
hlessani@shaw.ca
thanks bro
Old Jan 31, 2003 | 01:18 PM
Mikey97Z's Avatar
When I did my rebuild a few months ago I bought all the parts from D&D (bearings and seals, carbon synchros, steel 3-4 fork) and supplied them to a local tranny shop. I love my new tranny, it really feels good. Labor for the rebuild came to $999
Old Jan 31, 2003 | 01:27 PM
Punisha69's Avatar
what was your cost on ALL parts?
Old Jan 31, 2003 | 01:44 PM
97_TA_WS6's Avatar
I paid close to about 950 for labor and part but I did drop my own tranny.
Dallas, TX
Old Jan 31, 2003 | 02:03 PM
Mikey97Z's Avatar
I dropped my own tranny too. $500 parts, $1000 labor
