Exhuast Clamp Will Not Hold.
Old Jan 28, 2003 | 11:27 PM
Xride's Avatar
One of the tips on my TOTL exhaust is loose. I tried tightening it as much as I could, but just sheared it off at the nut. I bought a new stainless steal clamp, and tightened it as much as I physically could, but still does not hold it tight. Does anyone have any ideas on how I can make it tight wihtout welding it?
Old Jan 29, 2003 | 08:41 AM
EviLBoX's Avatar
Maybe try a different type of clamp? I assume you're using a U-clamp? You could try some clamps like this maybe?
http://www.jegs.com/cgi-bin/ncommerc...80&prmenbr=361
I'm not sure if this will work or not, you may just end up having to weld it.
Old Jan 29, 2003 | 09:56 AM
nateh's Avatar
If you cut two notches in the end of the pipe that slips over the other one and clamp it, it will stay put. The notches should be 1/16-1/8 inch wide and about 1/2 inch long. Align the notches so that they are at a relative 9 and 3 o'clock and the top of the u is at 12 o'clock.
G-BODYT56
Jan 14, 2022 11:14 PM
generaldave
Sep 25, 2015 06:48 PM
rideordie
Sep 7, 2015 08:22 AM
karpetcm
Aug 14, 2015 03:02 PM
ad356
Apr 11, 2015 08:49 AM
