cam dowel pin too long?
Old Jan 28, 2003 | 10:26 PM
kirschman's Avatar
Question cam dowel pin too long?
I did a search but would like to get one more opionion on the length. The pin in my 306 is 7/8 (sorry, tape measure is all i got) and the stocker is 5/8, . Can the pin be just hammered in or is it bottomed out already?
Old Jan 28, 2003 | 10:33 PM
Camaro37's Avatar
7/8???........wow, I hope no one has used it like that. Just tap it in carefully to .620" a tad bit less than 5/8.
Old Jan 28, 2003 | 10:34 PM
slashz28's Avatar
maybe you could try grinding it? i dunno, but the cam i bought off someone, the pin looked like it was grinded, and was too short for my car, so i yanked it out a bit. maybe you could try tapping it in a bit as well. or maybe the best solution would be to buy a new pin (for myself as well, cause i dont know if what i did is ok or not?) this didnt help, did it?
Old Jan 28, 2003 | 10:42 PM
Re: cam dowel pin too long?
Originally posted by kirschman
... Can the pin be just hammered in or is it bottomed out already?
You won't know until you try.
If it won't go, then it is time to reduce it's length by removing some metal.
Old Jan 28, 2003 | 10:44 PM
94 CAMRO Z28's Avatar
When I tried to tap in my pin for my hotcam it didn't want to budge. I just used a dremel and ground it down to correct length.
Aaron
Old Jan 28, 2003 | 10:46 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
LOL.. I just got my cam in and the dowel's not long enough!
So much for installing it tomorrow.
Old Jan 28, 2003 | 10:47 PM
Sounds like you guys need to swap.
Old Jan 28, 2003 | 10:49 PM
BackInBlackZ28's Avatar
Copied this directly from the GM performance parts catalog:
Technical Notes: The LT4 camshaft P/N 24502586 was designed to be used in a number of different engines. Therefore, the following change may need to be made to allow for correct assembly of the engine: For LT1 and L98 engines 1995 and before, the dowel pin in the end of the camshaft must be pushed in so extension from end of cam is .30+/-.01", the same as the production part. For 1996 LT1 and LT4 engines, the dowel pin is in the correct position, extending .620" from the end of the camshaft. This camshaft has a fuel pump lobe. _
Old Jan 28, 2003 | 10:50 PM
kirschman's Avatar
thanks for all the quick replies guys!! I'll try hammering it tomm., if that doesnt work I'll break out the dremel. Thanks again!! Chris
Old Jan 28, 2003 | 10:51 PM
Camaro37's Avatar
My CC306 had a hole all the way through for the dowel, meaning you could push it all the way out the otherside.
My hotcam had the hole filled at the bottom, so thats prolly why you had to shave some off.
Be careful tapping it in though, I have heard of the pin splintering if it gets hard to move. Mine tapped in very easily.
Old Jan 28, 2003 | 10:52 PM
That should be LT1s "1994 and before", since the 1995s got the vented opti and need the longer dowel length.
Old Jan 28, 2003 | 11:18 PM
haha.. I just got rid of my 306.. Trying something different now
Old Jan 28, 2003 | 11:22 PM
I meant dowel pins.
Old Jan 28, 2003 | 11:45 PM
Well, I was able to pull the dowel pin out - it's about 1.1875"... I can set it up to be .620 out, but it still can be pushed in very easily.. To about .450 or so.. I've tried to "knurl" it a little bit, and that seems to be helping. Maybe I can just set it @ .620 out w/ JB weld and call it done? What method have you other peop's used? Are the 96 and newer dowel pins like 1.5" long or what?
Old Jan 29, 2003 | 11:09 AM
bueller
rideordie
Nov 5, 2019 04:52 PM
AdsoYo
May 2, 2018 03:21 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
