Valve cover modifications ???
Old Jan 28, 2003 | 02:00 PM
Ben383's Avatar
Going to be buying some 1.6 roller rockers and need to know if or how to get the stock valve covers to clear . Thanks for all the help .
Ben
Old Jan 28, 2003 | 02:16 PM
jkayner's Avatar
all you need to do is clear the "web" fom inside the VC. You can either cut the middle part out or just bend it flat...
Old Jan 28, 2003 | 02:26 PM
Teal94Z's Avatar
But dont take the bolt guide out, you will have oil leaks out the *** just like I did!
Old Jan 28, 2003 | 03:21 PM
Ben383's Avatar
Thanks for the reply .
Ben
Old Jan 28, 2003 | 05:05 PM
DaveW 396ci's Avatar
it depends on the type of rockers you buy. Some won't clear the LT1 valve covers. I had problems with the Harland Sharp 1.6 rockers and had to clearance them to fit.
Stick with Crane Gold or Comp Cam Pro Magnum and you should be fine.
DaveW
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
