Setting pinion depth
I was wondering if anyone could help me. Is setting pinion depth that "big a deal". I've seen guys just re-use pinion shims when swaping gears in to the same housing.
This is my first gear swap and I'm not sure if I can just reuse the shim thats on the pinion or will I need to use a depth setter. I was going to re-use the pinion shim and adjust the backlash. Any thoughts?
This is a (1995) GM 7.5 rear.
kev93z28
Aug 19, 2002 12:48 AM
