power door locks
Old Jan 26, 2003 | 08:43 PM
95 firechicken's Avatar
power door locks
were is the power door lock relay located at for a 95 formula i've looked every were and can't find it
Old Jan 26, 2003 | 09:14 PM
Barry 94Formula's Avatar
I'd like to know also. My locks will open but they will not close.
Old Jan 26, 2003 | 09:19 PM
mine will lock but not unlock funny thing is when i hit the unlock button i get 12 volts on both sides of the accuator thats why i'm thinking the relay is stuck
Old Jan 26, 2003 | 09:24 PM
You can't find the relay because there is not one.
The switches control the lock actuators directly.
Old Jan 26, 2003 | 09:32 PM
i've put a different switch on and it still sends the 12 volts to both sides of the plug when i hit the unlock button but when i hit the lock it only sends 12 volts to one side of the plug
Old Jan 26, 2003 | 10:40 PM
ttt
Old Jan 26, 2003 | 11:27 PM
The ground actually comes via the lock switch on the passenger side. Try checking the connection there or that switch may be bad.
Old Jan 27, 2003 | 01:12 PM
SS Aloha's Avatar
Well, it get's more complicated than that. The door locks are hooked into the Retained Accessory Power Module, part #12135089 for 1994 - 1995. This is an electronic module which among other things keeps your window power active for a little while after you turn off the ignition key. The relays look to be part of the module and it's kind of expensive, around $80. It sits somewhere behind the dash, above the radio. I was never able to find mine and I didn't feel like pulling the dash. The problem with my door locks luckily turned out to be just a partially blown fuse.
Old Jan 27, 2003 | 01:28 PM
The RAP module does feed power to the locks, other than that, it has no play in the power lock system and there are no relays that feed back into the module.
The description of the problem seems to have nothing to do with that. He has power, so I did not bring up anything regarding the RAP module.
Old Jan 30, 2003 | 05:36 PM
thanks shoebox it looks like that was the problem
guruerror
Dec 12, 2020 06:32 PM
Heathen1
Jan 2, 2016 04:27 PM
EdgarArmada
Apr 18, 2015 05:20 PM
siguy
Nov 27, 2014 10:07 AM
XtremeLt1
Sep 13, 2002 08:50 PM
