Drop the pan or flush?
Old Jan 25, 2003 | 09:19 PM
jasons93z's Avatar
I was planning on dropping my pan and changing my filter and fluid tomm. But i was questioning whether or not it is better to drop or to have it flushed because if you dont flush it then the old fluid in the convertor stays in. But i also heard that flushing can be bad. So, what do you think? By the way my car has 70k.
Old Jan 25, 2003 | 09:24 PM
jasons93z's Avatar
also, is mobil 1 synthetic the best?
Old Jan 25, 2003 | 10:15 PM
jasons93z's Avatar
anyone
Old Jan 25, 2003 | 10:46 PM
AHARTZ28's Avatar
if the filter hasnt been changed i would do that then do a fluid transfusion not flush
Old Jan 25, 2003 | 11:03 PM
jasons93z's Avatar
i just dont see how removing half of the fluid is going to help. But i want to change my filter and if i have i flushed they wont change it. You may say that i can just change the filter now and put fluid in it (5 qts of mobil 1 costs $25)then have it flushed later but that would cost extra $$$ that i dont have right now so i dont know what i should do.
Old Jan 25, 2003 | 11:19 PM
1994TransAm's Avatar
well have them flush it, and fill it back up with the cheap stuff!!!!
then drive home and drain it change the filter!!!!!! use the good stuff after!!!
Old Jan 25, 2003 | 11:45 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Use ford's tranny fluid
NOT SYNTHETIC
TRUST ME ON THIS ONE
Old Jan 26, 2003 | 12:33 AM
jasons93z's Avatar
Why not synthetic Trey? Just wondering. Plus, do you think i should just drop it or flush it. Thanks
Old Jan 26, 2003 | 12:36 AM
treyZ28's Avatar
dropping it is fine.
synthetic isn't good for our trannies
Old Jan 26, 2003 | 12:57 AM
jasons93z's Avatar
One more question, i heard about a method where you take of the return line from the cooler and let it drain in a bucket for 5 sec while the car is running to get all the dirty fluid out. Does this work. Also, how do they get the fluid out of the converter when they flush it or do they? Sorry about all they questions, i am just paranoid about me tranny considering i just had one go out in my dodge ram. Thanks
Old Jan 26, 2003 | 12:52 PM
jasons93z's Avatar
so should i try the 5 sec thing?
Old Jan 26, 2003 | 01:07 PM
treyZ28's Avatar
dude
drop the pan
change the filter
fill it with ford fluid
your done
get a tranny cooler and deeper pan if your that stressed over it
Old Jan 26, 2003 | 01:12 PM
TobyZ28's Avatar
Originally posted by treyZ28
dude
drop the pan
change the filter
your done
I also took my car to some el-cheapo place to change my tranny fluid. they put some non Dexron III stuff and the thing would start to slip like crazy after a month or 2. I said screw that, took it to my good ol mechanic and he put in the right fluid... the car ran great after. Don't mess with alternative tranny fluid.. its bad =/
Old Jan 26, 2003 | 01:17 PM
treyZ28's Avatar
a GM 4L60E engineer and tester (he tests them on the prooving grounds) told me to use fords fluid. snythetic is not a good choice.
Old Jan 26, 2003 | 04:47 PM
JAFA's Avatar
If you decide to flush your tranny don't let them put any cleaner in before the flush or add a conditioner after the flush with the miles you have.
I work at a chevrolet garage and they don't recommend it.
