Water transfer tube removal... Am I asking for it?
Old Jan 24, 2003 | 09:18 PM
auslandt's Avatar
Well my clutch repair and general tune up has become a complete one over of every freeking square inch of this car. So far I found a bad water pump (leaking out the weep hole ), heater core is plugged (I hope that's all it is), the clutch of course, and now I seem to have tracked down a leak to the water transfer tube on the backside of the engine (between the heads).
Has anyone experienced a leak in this area?
I am wondering if just tightening the bolts will take care of the problem or if I need to remove the two bolts from the back of the heads and reseal. Also, is this going to require engine removal? I will be dropping the transmission so I think I can get to the passenger side bolt (this is the one I see leaking), but I can't even SEE the driver's side.
Any insight would be GREATLY appreciated.
(man I getting sick of finding little things, but at least I know the car will be in tip top shape when I'm through.)
Old Jan 24, 2003 | 10:03 PM
Well, if you have to remove either of the steam pipe bolts (and most people ruin them getting them out), I would replace them with the new, better bolts (GM PART # 12552974, need 2) and seals (10108689, need 4). If you end up wanting a whole new steam pipe assy, get 12556260 (for 1995-1997 cars). It includes the bolts and seals.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
Feb 6, 2015 10:40 AM
