Sensor that hooks to water pump? Identify its use
Old Jan 23, 2003 | 03:47 PM
ZDriver96's Avatar
There is a sensor on the lower driverside part of the water pump..
Does this sensor control take the temperature reading, then tells the fans to kick on when the car gets too hot?
Old Jan 23, 2003 | 04:04 PM
JohnD's Avatar
That is the sensor that goes to the computer. The one in the head goes to the gauge. I put in a dual unit in the water pump and now my gauge reads what the computer sees and not the fluctuating temps in the head.
Old Jan 23, 2003 | 04:05 PM
drop top steve's Avatar
Re: Sensor that hooks to water pump? Identify its use
The sensor on the water pump is the CTS or coolant temp sensor. It sends its signal to the pcm. The pcm uses this for turning the fans on/off thru the fan relays. The temp gauge gets its signal from the sensor on the left cyl head.
Old Jan 23, 2003 | 04:12 PM
ZDriver96's Avatar
Thanks guys thats exactly what i needed to know.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
