switching to 95 timing cover... will my non-vented opti work?
Old Jan 23, 2003 | 12:28 AM
Jesse_Boyer's Avatar
I'm going to a 95+ timing cover so I can run a Cloyes timing set. I'd like to know if my 94 opti will work with that setup. Let me know what you know.
Jesse
FYI, already got a CSI pump.
Old Jan 23, 2003 | 12:52 AM
Soma07's Avatar
Nope, you need a 95+ opti
Old Jan 23, 2003 | 12:58 AM
From the "Rebuilding the LT1" article:
FRONT COVERS
The front covers have been changed three times, once because of the changes that were made to the distributor and once due to OBD II.
The original cover had three holes, one for the crank, a small hole (@ 0.70") for the water pump drive and a second one for the small drive shaft for the distributor. It’s a 10128289 casting.
The second front cover still had the small hole for the water pump shaft, but it had a much larger hole (@ 2.63") that sealed on the outside of the distributor housing itself. It’s a 10214196 casting.
The second cover was modified again in 1996 to accommodate the crank position sensor that was located in the lower corner of the cover on the passenger side. This same cover was used for the few engines that were installed in 1997, too. It’s a 12550032 casting.
PHOTO OF 3 COVER DESIGNS
Old Jan 23, 2003 | 07:19 AM
94 NO TOP Z's Avatar
Yep.. hole is the wrong size plus that cam gear set can't run the non-vented opti. Need a vented opti and opti harness.
Old Jan 23, 2003 | 07:36 AM
Bawls's Avatar
Im looking at doing the same thing... Are there any timing covers that work with 93-94 non vented optis and still clear the cloyes chain?
Old Jan 23, 2003 | 07:45 AM
RunRiot's Avatar
Jesse,
In addition to what's already been stated, you will have to change the dowel pin in the cam to drive the Opti... and possibly drill out the front of the cam to allow the 95+ Opti shaft to fit. Some have gotten lucky, but most have to remove the cam to get the dowel pin out. And don't even attempt to drill out the cam while it's installed.
Bawls,
The issue is not the timing cover, it is that the 93-94 Optis were spline driven... and neither the Cloyes nor any other timing set except the stock 93-94 set is splined for the Opti.
Old Jan 23, 2003 | 07:46 AM
Smoke T/A's Avatar
Its not a matter of clearance with the cloyes chain. The cloyes cam gear dosent have splines to accept the coupler that drives the 93-94 opti. Hence the another reason you have to run a 95+ opti.
Joe
Old Jan 23, 2003 | 07:48 AM
Bawls's Avatar
I see... Thanks guys. SO there's really no way out of the conversion. Oh well.
Old Oct 22, 2008 | 11:58 AM
user 647483's Avatar
Funny, oldest thread I could find and still a topic discussed on a weekly basis LOL
Old Oct 22, 2008 | 01:05 PM
LT1Zcar's Avatar
Everyone looking for an opti- I bought a vented unit, new, from ebay for $83, $130 rush delivered. I have a decent amount of aftermarket mods, including ignition and coil, and i have had 0 issues with my cheap optispark. I GOT IT ON EEEEEEE-BAYYYYY
Old Oct 22, 2008 | 01:14 PM
Be careful with that, there are several threads here where people purchased
junk on eBay and ended up having to replace them.
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
Injuneer
Dec 15, 2014 09:36 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
