what makes higher numerical gears weaker
Old Jan 22, 2003 | 11:10 PM
atljar's Avatar
This was brought up in another post. I was under the long term understanding the higher numerical gears had more teeth on the ring, but smaller, therefore weren't as strong.
Another member gave me this info.
2.73s - 41 teeth on ring gear, 15 on pinion
3.23s - 42 teeth on ring gear, 13 on pinion
3.42s - 41 teeth on ring gear, 12 on pinion
3.73s - 41 teeth on ring gear, 11 on pinion
4.10s - 41 teeth on ring gear, 10 on pinion
4.11s - 37 teeth on ring gear, 9 on pinion <--
4.56s - 41 teeth on ring gear, 9 on pinion
He thought that they higher numerical gears were weaker because of the angle the teeth was different, thus making them weaker. Is that the correct reason, or is there something else which makes a lets say 4.10 weaker than the stock 3.42.
Old Jan 23, 2003 | 08:57 AM
BPS's Avatar
BPS
My first thought looking at this is that the 4.11 gear would be the strongest.
maybe the problem is that fewer teeth in the pinion causes slipping and cracking?
Old Jan 23, 2003 | 09:55 AM
Gripenfelter's Avatar
thinner teeth?
Old Jan 23, 2003 | 09:59 AM
BPS's Avatar
BPS
that's what I always thought but wouldn't fewer teeth imply thicker?
Old Jan 23, 2003 | 03:35 PM
jpaugh's Avatar
the pinion is thinner...
rideordie
Nov 5, 2019 04:52 PM
ChrisFrez
Dec 7, 2014 06:01 PM
Jul 4, 2005 05:00 PM
