tranny temp gauge on a M6???
Old Jan 22, 2003 | 09:50 PM
lillbush5555's Avatar
I have a autometer tranny temp gauge...and I just did a m6 swap...and I was wondering can I get it to work on the m6?? like take out the drain plug...cuz there is always fluid there and readuce it down untill my sensor fit in....would that work??
LMK
matt
Old Jan 22, 2003 | 10:25 PM
kgkern01's Avatar
I heard that the ZO6's have them on them, but I'm not sure, so don't hold me to it.
Old Jan 23, 2003 | 12:21 AM
96z's Avatar
96z
I have the same problem you do. I had a tranny temp gauge on my A4. Im going to use the drain plug "hole" like you said.
Old Jan 23, 2003 | 07:19 AM
Smoke T/A's Avatar
Re: tranny temp gauge on a M6???
LMK
matt
Matt,
Yeah it will work. When you got the guage new it shoud have cam with 2 fitting and the sensor. One fitting has a hole that the sensor will screw in to. It directly replaces the M6 drain plug on the passanger side of the tranny. HTH
Joe
Old Jan 23, 2003 | 02:39 PM
Laymaster's Avatar
How hot does an M6 tranny run anyway? How about an automatic?
Old Jan 23, 2003 | 03:15 PM
well lets see...before my a4 went out it was pegging the needle at 250 ehhe but it is supposed to run round 180 ish correct me if im wrong im not sure.
Old Jan 23, 2003 | 04:07 PM
JohnD's Avatar
I have a trans temp gauge in my m-6. It's in the drain hole in an adaptor fitting. I already had the gauge so I figured, why not. It slowly builds up heat in traffic in the summer and can get to 190-200 deg. F. finally. Usually, it's a lot less.
Old Jan 23, 2003 | 04:50 PM
Acceptable A4 temp at idle can be as high as ~260º. There is a temperature sensor in the tranny to tell the pcm what the temp is. It will throw a code when the temp reaches 306º.
Old Jan 23, 2003 | 05:16 PM
95 Z/28 LT1's Avatar
Super Moderator
Where did you mount the guage? I have one too but the cable for it is only like 4-5 feet long so it seems that would limit you a bit.
Magenta_Hearts
Mar 29, 2017 08:54 PM
dylan1303
May 22, 2015 12:24 PM
Biggiebound
Apr 21, 2015 11:28 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
