Gains from 2.73s to 3.73s
Old Jan 22, 2003 | 07:31 PM
Screamin96maro's Avatar
Cool Gains from 2.73s to 3.73s
Just curious on what my gains should be. My best run with kn cold air, z06 maf and SLP loudmouth on my factory 2.73s was a 13.71 @ 101.15 with a 2.103 60ft. Since then Ive added 3.73s with LT4 KM and pcmforless programming. What should I expect with the same weather conditions?
Old Jan 22, 2003 | 07:34 PM
96Z28man's Avatar
I'd guess around 13.3's, maybe 13'2's.
Old Jan 22, 2003 | 08:09 PM
1msfyter's Avatar
traction issue??? Also how do you like the ZO6 maf?
Old Jan 22, 2003 | 08:40 PM
Kain's Avatar
I gained a minscule amount from the 2.73-3.73 swap. Less than a tenth and mph.
Although I already had a torque converter before hand.
Old Jan 22, 2003 | 08:48 PM
ArrestMeRed's Avatar
Gears gave me about a .4 gain. But damn, is this a bitch to launch! you might not see any gains with out ET streets! LoL my 60`s certainly got worse!
Old Jan 23, 2003 | 07:14 AM
IDOXLR8's Avatar
Typically the gain is about 3 tenths if you are getting good traction.
Old Jan 23, 2003 | 08:05 AM
dabear95's Avatar
With my 60' time within .03, I gained .47 in the 1/4. And I had traction with the 2.73's, had to feather it off the line with the 3.73's.
My dad used to say that for ever 2 tenths you changed in the gear, you would get one tenth on the track. Just an approximation as tracks, cars, and drivers vary.
Jason
Old Jan 23, 2003 | 10:33 AM
CANTONRACER's Avatar
I gained about a 1/2 of a 1/10...not very much of a gain, certainly not worth the time I spent installing them and the money I spent buying the parts.
What most people forget to mention is what was the weather like with the old gears and the new gears? Track prep? Full tank, half tank?
Old Jan 23, 2003 | 05:23 PM
Remember I am expecting some gains from the LT4 km and PCMforless programming besided just the 3.73s. I was sayin if everything was the same ( track prep, gas,weather, ) Im sure its not going to be the exact same as it was when I hit my 13.7. I will be happy with a 3-4 tenth gain 2 tenths ahhhhh but not even a tenth or just that Im sure it has a gain. Im also going to be running either BFGs or ET streets.
Old Jan 23, 2003 | 06:38 PM
silver97Z's Avatar
Lightbulb
I picked up about .2 in the 1/8, but I installed 3.73s and Loudmouth at the same time so some gains are from the catback.
Current times are in the sig.
Old Jan 23, 2003 | 08:53 PM
dabear95's Avatar
Quarter tank each time. It was about 20 degrees cooler the week after the gears, but it was raining on and off that day. The track was definatly in better shape the week before with the 2.73's. But you make a good point, there are so many variables that we really can not say what gears will do for you. I can say for sure that the car feels ALOT faster and it IS more fun to drive!
Jason
Old Jan 23, 2003 | 09:41 PM
cop01's Avatar
well, after hearing all this bad feedback you probably arent wanting to do it........BUT on with some good news. I gained almost a full second with gears and a stall despite the fact that my 60' went out the window also....... maybe this will help
Old Jan 24, 2003 | 01:05 AM
94Zman's Avatar
When in between with 3:42's, 2/10ths consistantly in the same conditions with no tration issues. But, also most want a bit more gear....
Old Jan 24, 2003 | 01:42 AM
bunker's Avatar
atleast 2-3 mph is expected aswell.
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
colts0455
Sep 22, 2015 02:03 PM
cristian1311
Sep 12, 2015 08:16 PM
