Car eving to 6800, is this safe???
I'm hoping it is. I got it reprogremed from PCMforless and put a new cam and springs in it, but I still have the stock rockers. Is this safe for it to rev that high?
You might be able to get by with it for a little while. Personally, I wouldn't do it with stock bearings. What kind of oil pressure do you have? Did you have your heads ported to go with the cam? I'm assuming it's a pretty good size cam since you're wanting to rev it that high.
I have the same program for my car, but I dont have an aftermarket cam yet! I have heard that there is no need to shift at 6600rpm's or higher because your power starts to fall off way before that.
http://groups.msn.com/WashingtonFBod...to&PhotoID=439
Make sure you have the right valve train and hold on!
I must admit I have only been doing this for three years now
On the dyno my 306cammed car(w/lt4 heads)made peak hp @ 6300rpm!,shifts out of 1st and 2nd at 6400rpm,no reason to go any higher,sooner or later something is going to give going that high on rpm!
Originally posted by Kuppler
That is what I was thinking aswell. I'm getting it Dynoed soon so I can see where that drop off is.
Originally posted by White_94_TA
LT1 with Hotcam kit, Gold Race rockers, Hooker LT's, Y pipe and Borla.. . Power peaked at 6500rpm and held till the 6800rev limiter.
A hot cam car peaking at 6500rpm? are you sure?!!!!
