A/C Compressor removal questions
Old Jan 22, 2003 | 10:24 AM
John Winkeler's Avatar
Guys,
I want to remove the A?C compressor and clutch as a unit from my 1996 Z28. Are there any gotchas I should know about before I undertake this effort?
Will long tube headers get in the way of manuvering the assembly out of the car?
Thanks,
John
Old Jan 22, 2003 | 12:45 PM
Fuels94TA's Avatar
It should be s straight forward job. 3 bolts in the front on the A/C unit. Once those are out you can move the A/C forward to reach the 1 bolt in the back which is the A/C compressor line. Then slide it forward then tilt it downward. You might have to remove the compressor line cause it will be in the way. Once done you'll need the 1LE pulley were the A/C use to go. You'll see how easy you can reach your plugs. Dont forget to drain the freon.
Vinny
Old Jan 22, 2003 | 12:55 PM
Vinny,
Thanks for the info. I was hoping that the compressor could come out the front.
John
Old Jan 22, 2003 | 02:29 PM
Fuels94TA's Avatar
Originally posted by John Winkeler
Vinny,
John
You mean as in were the belts is? I will slide forward towards the radiator.
Vinny
Old Jan 27, 2003 | 01:05 PM
Vinny,
Yeah, I was concerned that the compressor would have to come out to the rear and get all screwed up with the long tubes. From your response, it appears that the compressor comes out from the front of the engine (toward radiator).
Thanks again,
John
Old Jan 27, 2003 | 01:59 PM
Fuels94TA's Avatar
Vinny,
Thanks again,
John
John, it should slide out foward not backwards into the headers. Like i said remove the three bolts in front of the A/C. Then there should be one bolts were the feron goes. unplug the elec. plug into the A/C. Now it should be loose. The trans line are in the way but you can move them. Just don't but to much force on it that it will break. You should be able to slide it out with care.
Vinny
Old Jan 28, 2003 | 01:04 AM
Lt1t56's Avatar
I did my compressor last year and found it a lot easier to remove with the front sway bar loose and hanging down a little to give clearance for the compressor to come out. Just wanted to add that, it helped me out.
Old Jan 28, 2003 | 10:07 AM
Thanks for the tip about the sway bar.
John
99TransAmWS6
Feb 12, 2015 07:23 PM
alphaauto
Feb 5, 2015 05:25 PM
alphaauto
Jan 23, 2015 07:42 AM
cmdeshon
Dec 27, 2014 10:06 AM
pologreen97z
Dec 2, 2014 10:42 AM
