throttle blades
Old Nov 7, 2009 | 09:10 PM
camarowayne's Avatar
throttle blades
If my throttle blades are not closing do I have to replace the throttle body or just get a rebuild kit for it or wat do I actually do. Its a bbk58mm.
Old Nov 8, 2009 | 08:54 AM
Is the stop adjusted to prevent them from closing fully? Are you experiencing an intermittent problem with the blades not returning to the normal closed position? Have you tried lubricating the shaft? Have you tried adjusting the spring? Have you checked the cable or adjustment and binding?
Old Nov 9, 2009 | 02:13 AM
the stop is not even near the adjustment futher back. Already tried to lubricate no result, but the spring does stick from time to time. Is there a way to change the spring,and I think that is why it is hard to hit gas sometimes.
PopoFormula
Oct 12, 2015 04:19 PM
truecontr3
Oct 11, 2015 09:30 AM
football4life
Oct 4, 2015 07:48 AM
surreybrad
Sep 29, 2015 09:00 PM
KYWes
Sep 26, 2015 08:49 AM
