Wiring question (config)
Old Jan 21, 2003 | 11:53 PM
RHPF's Avatar
Ok I am going to get either 2 Infinity Kappa Perfect 12.1 or 2 " 12.1d (dual voice coil). I am going to be using a MTX 6500D amp to power them, it produces around 750 watts rms at 2 ohms bridged. I cant think at the moment but which of the two subs should I get to achieve 2 ohms bridged (dvc or svc)? Thanks if its the dvcs also explain how to wire it, if its svc its kinda obvious. Thanks
Old Jan 22, 2003 | 12:45 AM
RHPF's Avatar
Oh and crutchfield says that the Perfect 6.5 does not fit in the front of a 99 trans am. Anyone know if thats true (like in the stock component locations)
Old Jan 22, 2003 | 12:37 PM
firebirdude's Avatar
You will want the single voice coil design. (12.1) They have 4 ohm coils, so you will want to wire them in parallel. Positives together and negatives together.
And do you mean Perfect 6.1 ???? I don't see a 6.5 set. Unless you are meaning 6.5 inches! they maybe right. Our stock locations are 6.75" , but many 6.5" will fit. Some do. Some don't. To be sure, buy the adapters to make our holes 6.5". Crutchfield sells them. They are part number 142SAC656 ($12.00/pair).
DirtyDaveW
Dec 1, 2016 05:37 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Jan 4, 2015 11:15 AM
lbrowne
Nov 13, 2011 04:25 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
