P1860 Code
Old Oct 27, 2009 | 10:49 PM
hankm7's Avatar
P1860 Code
I just found out the transmission that my cousin put in this car is from a 94 TA. I read on another thread that there is no TCC solenoid in that year 4L60. Is that right and if so, will it work ok and how can I get rid of that SES light and the P1860 Code? Can I wire a 10-15ohm resistor to the tan/blk wire. Is that the answer? The PCM is the original 96.
Help me... I'm tired of searching threads
Old Oct 28, 2009 | 08:49 PM
hankm7's Avatar
94-02 4L60e all have the TCC solenoid. So long as it has the electrical connector it's all the same..right??? Dag I thought I was going to get out easy. Does anybody want to give me an idea of what I'm getting into. I am so close to getting this car ready for inspection. This is my last hurdle. I guess I'll test for 10- 15 ohms at the PCM and if it ain't there. Get a new Solenoid and Harness for about $50- 60. Is that right?
I think there should be a special forum for me called "DIY for Dummies"
I think The Moderators are tired of my lame questions. lol
Thanks for any help.
Old Oct 29, 2009 | 01:03 PM
hankm7's Avatar
Ok, I dropped the transmission pan to see what exactly I have here. I was told that it ws a 94 but they weren't sure.
This is what I found. So now I'm back to trying to fool the PCM....right?
I can't wait for someone to jump in here and help me get this squared away. Looking forwards to hearing from anybody. Thanks
Old Oct 29, 2009 | 02:25 PM
Performabuilt's Avatar
Supporting Vendor
Ok the trans is a 94 your showing, You can use it however. You will need to swap the wiring harness from the 96 trans and the missing solenoid. It will act as a dummy for the PCM and all will work fine. There is no valve train in the 94 for the solenoid but all will fucntion fine as long as the pcm sees it .
Old Oct 29, 2009 | 05:18 PM
hankm7's Avatar
I've been reading your advice to other people. That's why I pulled the pan to actually see what I have.
I don't have the old 96 trans so I guess I need to find a Harness & Solenoid to do that. I'm going seaching/reseaching for that now.
Thanks!
PS I have been told that I can reprogram the PCM so it doesn't look for the PWM. Will that work? Either way I'm stoked! Thanks again
Old Nov 1, 2009 | 11:37 AM
hankm7's Avatar
I found a harness and solenoid at the salvage yard. Cost me $7.00. Put it in and MIL LIght is off. Thanks Pefomabuilt
Hank
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
