Cost to replace rear end and brake lines
Old Oct 10, 2009 | 01:08 AM
xrayman's Avatar
Hello all, looking at a 00 B4C with 132k, sellers states it needs brake lines and rear end. Worst case how much will this cost to do? I don't have the time to or no how do this myself. Any responses would be appreciated
Old Oct 10, 2009 | 03:37 PM
You should be able to find a rear axle assembly in a junk yard, or even in our "parts for sale" forum... about $300. Installing it would run about $100-150 (2 hours of labor, max).
Brake lines depend on which lines your asking about, and whether the car has 3-channel ABS or 4-channel ABS + TCS. If its the hoses that connect from the body to the lines on the rear axle, plus the rubber hoses that connect to the caliper on each brake, you can get a set of braided SS lines for $120 (3-channel) to $145 (4-channel). Now you're probably talking about 2 - 3 hours of labor by the time they replace the hoses, bleed the lines.... $150 - 225.
Depends on the labor rates in your area.
If he's telling you it needs all new metal brake lines, its going to be way more expensive than that.
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Jazsun
Dec 29, 2014 12:14 PM
