U-joint removal
Old Oct 9, 2009 | 06:16 PM
nlopez108's Avatar
Question U-joint removal
Does anyone know the best way to remove u-joints from the driveshaft? Its for a A4 2000 Z28.
Old Oct 9, 2009 | 09:59 PM
greenmachinedriver's Avatar
i use a balljoint press and a hammer. you can also use a vise and a large drift punch. its not really that hard to get them out but putting them back in is the trickey part. you have to take the caps off the new joint toget the new one in and then hammer or press them into the driveshaft without letting any of the needle bearings fall out. it takes some practice to get good at.
Old Oct 10, 2009 | 05:48 AM
AL SS590 M6's Avatar
Moderator
The factory joints are glued in with a plastic substance. For easy removal you'll need to heat them with a torch (a small plumbers propane torch will work) until the plastic melts and starts squirting out, then use one of the above mentioned methods.
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
