ideal PCM for forced induction setup
Old Sep 20, 2009 | 06:22 PM
leftoverz28's Avatar
I have both a speed density and obd II pcm and harness, one out of a 93 and one out of a 97. Was wondering which would be best in regards to tuning for a forced induction setup. I realize that burning the chip for the 93 computer is a pain, but i don't know much about tuning with OBDII. Im also not sure if i should just break down and go with an aftermarket setup.
Old Sep 21, 2009 | 01:31 AM
MikeGyver's Avatar
How much boost are you running? The stock computer will do 15psi of boost on an LT1 quite well in speed density mode, we have alot of guys doing it here with a 2 bar tune.
Old Sep 21, 2009 | 11:39 PM
i dont plan on running more than one bar anytime soon. Is this possible without changing the factory tune?
Old Sep 22, 2009 | 12:30 AM
MikeGyver's Avatar
Yes, if you use an MSD BTM box and pull about 2 degrees per psi of boost. There's other stuff that should be changed in the tune anyway though.
Old Sep 23, 2009 | 11:14 PM
dookie454's Avatar
Trust me, if you pull 30 degress of timing (15psi x2) you would be better off running no boost at all. 3 Degress of timing at WOT is not good for power.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
Jun 8, 2015 11:38 PM
Bignasty85
May 8, 2015 11:48 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
