window switch panel cracked
Old Sep 10, 2009 | 07:53 PM
lovemyblackz28's Avatar
It seems one of the clips cracked. I cant locate a part. Any ideas?
Old Sep 10, 2009 | 08:11 PM
Spartan7's Avatar
You mean the metal clip itself cracked? Usually the plastic around the clip goes first. If it did, just glue the clip back in. If your clip is broken or missing, try a junkyard.
Old Sep 10, 2009 | 08:26 PM
The clip cracked. It must have fallen into the door. They dont make this pat anymore. Makes the car feel old when I hear that Are there any older chevys with similar clips?
Old Sep 10, 2009 | 10:02 PM
GM PART # 9722397 for the metal clip still shows up at gmpartsdirect.com, so I would say you can still get them.
Old Sep 11, 2009 | 11:04 PM
blacknight's Avatar
I had where the metal clip slides into break off. So mine was looking like you pic so I ended up epoxing the whole thing. This all happen from repeated times of removing it and the door panel for window motor replacement then the speaker rattled from a loose bolt then the window rattled. Oh well if I have to removed it I will probable break lots of stuff.
Old Sep 12, 2009 | 09:31 AM
SSCAMARO1659's Avatar
may have a guy in ny that has that part, I bought some parts from him about three weeks ago and he had that still. I needed the bezel that went around the door handle. If you want I will look for the number and you can call him to see if he will ship it to you.
steve
Old Sep 15, 2009 | 08:33 AM
My Red 93Z-28's Avatar
Ordered the clips from Jason Cromer Friday. I think for (4) of them it was $3.xx
Old Sep 18, 2009 | 08:38 AM
That site doesnt have a pic of the part. Was just wondering if there is a pic and why is it under key fob?
Old Sep 18, 2009 | 08:41 AM
They are little V-shaped spring clips
Old Sep 18, 2009 | 11:05 AM
http://shbox.com/page/W1.jpg
Under the key fob? It is under the panel to hold it on.
Old Sep 18, 2009 | 11:46 AM
Im sorr, let me be more specific. I meant on the gmpart site, when I put in the part number, it says key fob for the part.
Old Sep 18, 2009 | 01:56 PM
grumpygreaseape's Avatar
this recently happened to me during a window motor replacement. i grabbed a flashlight and a retrieval magnet and fished out the clip. pulled off the switch bezel from the car. mixed up a dab of jb weld and epoxied it together, 24 hours later i re-installed it. it was tight and good as new. seem like you need to dig out your old spring steel clip from inside the door.
Old Sep 18, 2009 | 04:52 PM
Originally Posted by gmpartsdirect
GM PART # 9722397
CATEGORY: Keyless Entry Fobs & Batteries
PACK QTY: 25
CORE CHARGE: $0.00
GM LIST: $1.19
OUR PRICE: $0.71
DESCRIPTION: CLIP
It says it is a clip.
willismoons
May 27, 2015 04:03 PM
MichiganSkip
Aug 31, 2002 08:52 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
MichiganSkip
Aug 16, 2002 08:17 PM
Redbird
Aug 2, 2002 06:50 PM
