True duals
Old Sep 8, 2009 | 09:32 PM
revolution79z28's Avatar
True duals
Is it mandatory to knotch the frame on the driver side? I have Pacestter LTs. I'm going to run a 2.5" x-pipe system with red hot flowtech dumped and if I need to knotch the frame then I gotta do more reasearch.
Old Sep 9, 2009 | 06:35 AM
wrd1972's Avatar
I did no mods to the chassis with my TD's.
Old Sep 9, 2009 | 01:50 PM
reamo04's Avatar
never heard of knotching the frame. heres a link with some true dual pics (located at the top of the exhaust forum)
https://www.camaroz28.com/forums/sho...d.php?t=598251
Old Sep 12, 2009 | 10:54 AM
Do I need to shield the fuel lines on the driver's side? What would be the best thing to use to keep the heat off of them? How should I point my turndowns? Straight down, towards the outside of the car or towards the inside of the car? I'm also going to run an H-pipe system instead of the x-pipe system.
Old Sep 12, 2009 | 03:06 PM
reamo04's Avatar
point them so they are at an angle so facing like a 45* facing out from the car and backwards
Old Sep 18, 2009 | 08:54 PM
silverz28's Avatar
I notched mine. Here is a thread about it.
https://www.camaroz28.com/forums/sho...d.php?t=697807
Old Sep 19, 2009 | 08:28 PM
Thanks for the info guys. Did you know that you needed to knotch the frame before you did the exhaust work or found out after the work was done? I'm not a welder so I think I would have to get someone else to do that but if I don't have to have it done then I won't bother with it. Could I have the pipe knotched instead or will this restrict the flow of exhaust? I thank you guys for taking the time to answer my questions. I just want to get input from ya'll before I make up my mind.
Old Sep 20, 2009 | 12:47 PM
silverz28's Avatar
I'm sure there is other ways around. That just worked best for me. Do some more searching and you will find other threads about this subject. But no, you don't have to notch.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
