Suddenly no 1st or 4th gear..A solinoid??? where to get?
Old Sep 4, 2009 | 05:58 PM
..DAMN..'s Avatar
I just had the tranny rebuilt 19k miles ago and today i noticed it was taking off in second and not shifting into 4th..So after searching here im thinking it is a bad A solinoid?
What do you think? How hard is it to replace and how much? would it be better to take to a shop?
Old Sep 5, 2009 | 05:36 PM
..DAMN..'s Avatar
noone?
Old Sep 6, 2009 | 12:33 PM
Performabuilt's Avatar
Supporting Vendor
its easy to replace and you can get one at the dealer for like 30 dollars . If you can change filter you can change solenoid
Old Sep 6, 2009 | 12:43 PM
RUDEDOG's Avatar
Yes it is easy. Unless the clips are in backwards. If they are you have to remove the valve body. I ran across this on my 95z a4.
Old Sep 6, 2009 | 04:04 PM
..DAMN..'s Avatar
Thanks guy's
There are two solinoids right next to each other which one is the 1-2 solinoid?
Old Sep 7, 2009 | 10:19 AM
Supporting Vendor
The 1-2 is the one that feels like its spring loaded , the 2-3 just kinda flops feels loose.
Old Sep 8, 2009 | 03:14 AM
..DAMN..'s Avatar
Ok my tranny suddenly started shifting normal again and has been the last few days what could cause that?
Old Sep 8, 2009 | 07:49 AM
RUDEDOG's Avatar
It doesn't sound like an electrical problem. If it was I would think it would latch a code.
Old Sep 8, 2009 | 08:20 AM
blown94's Avatar
You've already been told what to do, from a board sponsor that builds transmissions. I concurr with him. Not to sound like an ***, but if you want to drive around and wait for the solenoid to completely **** out on you at the wrong time, then by all means go ahead. If you want to fix it instead of pay for a rebuild, you will do what you were advised to do. I would change both while in there.
Old Sep 10, 2009 | 12:49 AM
..DAMN..'s Avatar
Right i guess i will just walk to work everyday..walk to pay my bills and to get food...not trying to sound like an *** but your post was worthless.
1-2 shift solinoid was bad along with the kickdown and pwn solinoid none were ohlming out thanks perma for the help.
Old Sep 12, 2009 | 06:07 PM
blown94's Avatar
I dont think I ever told you to walk anywhere. I told you to fix it, like the man said. I build transmissions as well, and I said I concurr with him, go fix it, instead of driving around saying "well today it was shifting" and waiting for it to strand you somewhere, because you're too hard headed to change a couple $20 components like you were advised. Most anywhere you would have taken it would have sold you a rebuild, the man gives you the fix, and you question his expertise by re-posting and I agreed with his advice to re-assure you and then you come back saying my post was worthless? Get a clue.
David Dempsey
Mar 12, 2016 12:42 AM
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
Fatdog2
Sep 16, 2015 11:04 PM
