help with z pack install
Old Sep 4, 2009 | 04:50 PM
jcornss's Avatar
I'm installing a 3-4 z pack in a 4L60-e and only have .038" clearance. .050-.070 is specified in the instructions that came with the z pack. Do any of you guys know if raybestos offers thinner 3-4 pressure plates to use with the z pack? Is there another simple solution?
Old Sep 7, 2009 | 10:23 AM
jcornss's Avatar
There are no steeles in a z pack set up. The disks are one sided. Friction on one side, steel on the other. It also comes with it's own apply and pressure plates. I haven't found different thickness plates anywhere.
Old Sep 7, 2009 | 03:46 PM
Performabuilt's Avatar
Supporting Vendor
For performance use we have had good luck at .020 to .030 and if you use the stock plate in place of the one raybestos provides ussally thats what you end up at .
Old Sep 20, 2012 | 01:29 PM
ROCNDAV's Avatar
Re: help with z pack install
Sorry for the Zombie thread, but I am rebuilding a tranny for a buddy.
He bought the zPak kit.
After installing it, I have .060" clearance.
I usually like to run .025-.030" with conventional clutches & plates.
Installing that secondary steel plate that goes between the top clutch plate and backing plate brought me down to .010". That makes sense, since it is .050" thick.
So you haven't had a problem installing a thicker backing plate and running the clearance at .025-.030? Daily driven fbody, not a drag car.
Nov 18, 2023 07:21 PM
PROJECT X
Apr 17, 2015 12:13 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Jan 23, 2015 01:13 PM
Moshbmx1
Jan 20, 2015 03:27 PM
