Cleaning Headlights
Old Jan 19, 2003 | 03:09 PM
bman99's Avatar
Cleaning Headlights
Ok, I have a 99 Camaro with the bug-eye headlights and they're not nearly as clear as they use to be. What can I use on the plastic lenses to bring them back to the way they were when it was new? As a note, I've checked to see if they're leaking water in and they're not, so I know that's not part of the problem. Thanks,
Brandon
Old Jan 19, 2003 | 03:13 PM
MikeLS's Avatar
You'll need a plastic polish....
Zaino, 3M, Mother's, and Meguiar's all make plastic polishes used for restoring lenses and other plastic pieces.
As a side note, you can also use a general metal polish as well if you already have some....
Old Jan 22, 2003 | 05:49 AM
Severous01's Avatar
the plastics that the factory uses suck. they will begin to yellow in a matter of months. look for aftermarket clears or replacement lenses. i had a mustang that had yellow headlights, 100 bucks later and four screws, better than new.
Old Jan 22, 2003 | 08:19 AM
blkZ28Conv's Avatar
Plexus
Look into Plexus. This is plastic cleaner and protectant. Widely used by motorcyclist to maintain clear windscreens and helmet visors. This is really good stuff. Great for cleaning interior tint on windows also. If you need a slightly stronger polishing agent, try Meg #9 and follow up with Plexus. Plexus should solve your problem unless the lens are beyond repair. There are many plastic cleaners out there but the main thing is to polish and protect the plastic lens often ( several times a year).
Old Jan 22, 2003 | 08:31 AM
Darth Xed's Avatar
If the seal broke somewhere on your headlight... the mess could be on the inside of the lens... if so, you're best bet is a replacement...
2QUIK6
Sep 17, 2016 02:31 PM
Henson071
Dec 30, 2015 09:55 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Henson071
Aug 4, 2015 09:32 AM
alphaauto
Jul 26, 2015 04:40 PM
