White smoke, smells like coolant, rattling: anyone wanna take a stab?
Old Jan 19, 2003 | 01:39 AM
KASR_Z28's Avatar
Well, tonight i took my friend in the TA for a spirited n20 run cuz he'd never been in a juiced car. I was running 125hp dry shot and sprayed three times in 2nd and twice in third. At the end of last run in third as i let off of n20 and the gas, we hear a rattling sound...kinda like something was brushing up against a fan or something....car is running fine....no loud bangs, bumps, or grinds.
But about one minute later as i'm driving to a nearby parking lot to see what happend, i notice the white smoke that's coming out of my tailpipes. I get out, and the fast rattle is reduced to a steady knocking (but not really knocking) soundsm rhythmic with the idle. When i move the accelerator and give some gas, the rattling increases. The smoke smells like coolant, oil is fine - no burnt oil smell, no milky oil in the dip or from the breather.
I decide to limp her to a nearby apartment parking lot (i used to leave there so it'll be fine for tonight...there was NO WAY i was limping her 25 south to home) and you should have seen the SPYHUNTER smoke screen my car put up! I mean, the smoke was bellowing out of the back of my car.
the rattling continues and there seems to be a slight to moderate surge in power while driving, that in 2nd to higher gears seems to smooth out.
Anyone wanna take a stab at it?
KASR
Old Jan 19, 2003 | 01:14 PM
gb95zconv's Avatar
Sounds like you at least have a blown head gasket. You need to check the plugs to see if you detonated a cylinder as well. Coolant in the cylinder may have caused damage to rod/piston assembly...thats my guess for noise source.
Old Jan 19, 2003 | 09:13 PM
mnypitTA's Avatar
You blew a headgasket. Or maybe 2. Sounds like you also might have gotten some water in a cylinder and did some bottom end damage. Just because there is no water in the oil does not mean you did not blow a headgasket. It sounds like the coolant is blowing into your exhaust.
HTH
Old Jan 19, 2003 | 09:16 PM
rskrause's Avatar
Moderator
The motor needs to come out when this happens. At a minimum, you could drop the pan and check the bearings. But if it were me, I figure it's time to freshen it up, at the least.
Rich Krause
Old Jan 23, 2003 | 07:32 PM
Kyle@CSS's Avatar
head gasket. I blew 2 this past year. I changed them in my front yard both times. First time water in my oil. drove it home from the track like that. 2nd time just had exaust going into my water jacket. coolent was coming out of my overflow bad. I would pull the heads. Check the plugs. And go from there. The bottom end might be fine. When you have the heads off turn teh motor over and check the culinders for damage and to make sure the pistons are tight. and that they come all the way up. drain the oil and inspect it for any metal or anything. You can pull the pan if you want also. good luck.
Old Jan 23, 2003 | 09:03 PM
jcolez28's Avatar
Head gasket for sure. The ticking could be more severe damage like a broken rod or bad main bearing. Be sure to have your heads checked for warpage or you will put it back together and blow it again. You can help prevent this by not hitting the juice below 3000 RPMs. Your dry system probably siezed an injecter.
blac94Z
Feb 15, 2021 09:43 PM
dylan1303
May 22, 2015 12:24 PM
captcorvette
Mar 7, 2015 12:37 PM
MattFick
Feb 15, 2015 10:16 PM
blac94Z
Jan 12, 2015 05:44 PM
