need photo of hose to heater core
Old Aug 14, 2009 | 05:06 PM
Lost's Avatar
I need a good photo of the hose that comes out of the bottom passenger side of the water pump that goes to the heater core (passenger side). I need to see the flow restrictor valve - it should be a plastic piece on the line just a couple inches from the water pump.
From what I can tell mine has fallen off, I only have the two hose ends with nothing in between. GM doesn't have a supplier for the $30 part but they do have an assembly with the part ($170) and I can't spend that right now. I did get something that I think might work off of a junked LT1 Caprice but seeing as how I don't know what the original part looked like I can't see if this Caprice piece is even close.
Thanks.
edited to say that autozone doesn't appear to have an aftermarket piece either. If anyone knows of a source for the part then I would appreciate that as well.
Old Aug 14, 2009 | 05:20 PM
Other people have seemed to be able to get the part at their local auto supply (including Autozone). You could just join the hoses together with a hose barb (union) temporarily. Some to that as a permanent fix.
GM PART # 10188036 at the dealer.
Old Aug 14, 2009 | 05:34 PM
n2ceptor's Avatar
Carquest part # 277608 interchanged from the # Rob gave... Heater Control Valve cost around 13 dollars..
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Noct
Jul 14, 2015 01:18 AM
ducttape1975
Jul 10, 2015 06:29 PM
cmsmith
Jul 5, 2015 07:23 PM
Slayer
Jul 4, 2015 03:06 PM
