Help! RPMs high all the sudden!
Old Jul 16, 2009 | 04:24 PM
Snoman73's Avatar
I have a 95 3.4 v6. I have taken very good care of it but i recently took it on a 300 mile trip, on this trip i rolled over 200k miles on the car.
Have been back a couple of weeks now and everything seemed fine. Until yesterday.
Normal startup: crank, rpms sit at a low ~1ish, at 60mph, ~2 to ~2.5, gunning it to pass some slow person 3rpm
Yesterday and today: crank it, sit in park, at 2.5-3rpm, shift to Rev. drops down to ~2rpm, shift to ODrive it goes to almost 3rpm. I can put it in rev and just take my foot off the brake and i fly backwards much faster then my normal reverse speed. At red light/stop sign, i can just take my foot off the brake and get up to 20mph roughly without touchin the gas peddle once, lol, i can effectly 'cruise control' at 55 and 60 just by taking my foot off the gas and sitting there almost
as you can imagine, with such high constant RPMS, it takes some extra caution to slow down and stop, driving like this will ruin my brakes extremely fast.
my only guess is: IAC valve is faulty, Throttle position sensor is faulty, Throttle body/and or cable is malfunctioning, maybe something to do with oil pressure? not sure here, kinda at a loss here as it happened all of the sudden
also, disconnected battery, cleaned IAC valve, TB, checked connections, checked oil, seems fine, so why the high RPMs all the sudden?
any ideas? could really use some help!
Old Jul 16, 2009 | 07:44 PM
slo bird95's Avatar
i had the same problem in a 94 3.4 i actually replaced the iac and tps at the same time since they are inexpensive parts. The problem was fixed after that, it was definally a annoying problem though.
Old Jul 18, 2009 | 09:19 PM
DeLaRosa25's Avatar
check vaccum lines
Old Jul 20, 2009 | 12:09 AM
Snoman73's Avatar
fixed it, IAC valve thanks
(also had a leak on the PCV valve elbow, fixed that too while i was at it)
blac94Z
19
May 13, 2015 04:50 PM
warmeck
May 7, 2015 02:10 PM
reww86
Apr 27, 2015 05:17 PM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
