got a SC...need advice
Old Jan 16, 2003 | 02:36 PM
kahouna23's Avatar
Question got a SC...need advice
I got a Vector-Powerdyne unit as a "late" Christmas present and I need some advice on upgrading my internals. I posted this on the Forced Induction thread, but only one person replied. Hopefully you guys can help me. I'm looking for some web sites to get information on forged "dish" pistions and connecting rods so I can lower my compression. I also have a question about the valve train. Am I going to need stiffer valve springs and all the other goodies? I'll only be running around 8-9 lbs of boost. The manual states that 9 lbs of boost is the max you can run with stock internals, but I want to do it right. I don't really want to join the "rebuild club" if you know what I mean?! I also have a question about getting the block bored. Has anyone ever done that to a 3.8, and if so, is it even worth it? I've also heard about getting the cylinders sleeved if the wall thickness isn't enough to bore. Is it possible to do this to the 3.8? There's something about having a "bullet proof" cylinder wall that apeals to me....well, not really bullet proof, but you know what I mean. Any information on this subject would be GREATLY appreciated. I'm pretty much at a stand still until I can find some info. I hate coming home seeing the box in my garage and not being able to put it on....can you feel my pain??
Old Jan 16, 2003 | 03:57 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
you dont want to be a member of the rebuild club? well if you are going to upgrade the internals, that will be a rebuild...
your stock valve springs should be fine as long as you dont throw in a new cam
the sleveing process is if you have an engine block that has already been rebuilt and bored out and if you bore out anymore it will be boring the actual block, your block already has sleves in it from the factory. so resleving it will be of no advantage
i say strap that thing on if you break something rebuild it later
Old Jan 16, 2003 | 04:43 PM
HPbyChevy's Avatar
Thumbs up
I agree! Put it on and have fun!
I'd venture to say, your compression is already low enough. My '97 is running stock 9 to 1, and I'm getting ready to strap on a 6 lbs. blower. Eventually down the line I'll do the internals, but 'til then... I'm runnin' what I got.
(what's the worst that can happen? I'll have to walk back to get my truck and trailer - after I've picked the guts of my 3.8 up off the pavement and haul her home - to do a rebuild.... but damn, it was fun while it lasted!)
Old Jan 16, 2003 | 07:14 PM
kahouna23's Avatar
Okay...if my stock compression is good for 9 lbs of boost then where can I find some forged pistons? Another question, if stiffer springs are recommended, what ratio would be the best for my application?
Old Jan 16, 2003 | 08:58 PM
#7's Avatar
http://www.projectvirus.com/engine.html
Something to look at?
Old Jan 17, 2003 | 12:03 AM
kahouna23's Avatar
NOW THAT'S WHAT I'M TALKING ABOUT!!!! Thanks #7... you the man!!!!
Old Jan 17, 2003 | 07:28 PM
2turboz28's Avatar
go to www.ammperformance.com . he has a ton of stuff for v6 fbodies
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
