Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Crank sensor prob plz help
Old Jul 7, 2009 | 11:21 AM
josh77888's Avatar
Exclamation Crank sensor prob plz help
on a 94 camaro v6 it has 2 sensors, one is a 24x ref and the other is a 3x ref.
now if the the 3x is not hooked up or damaged it will not throw a spark at the wire correct??? cuz right now im getting no spark.
also could someone give me a pic of the 24x sensor wiring cause i had to wire it up myself the connectors on the harness were cut out.
thanks all help is greatful.
Old Jul 8, 2009 | 10:18 PM
According to the wiring diagram in my Chiltons (always a crap shoot on accuracy), there are 3 wires that connect to the 24X optical sensor. Pink is 12V power from fuse #11 (Ignition) in the underhood electrical center; brown/white is the signal wire, to pin C25 of the PCM; pink/black wire is the ground to pin C18 on the PCM.
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
Queens94z28
Dec 20, 2014 09:11 PM
JurisAg02
Jul 27, 2002 11:49 AM
