so whos runing e85
Old Jul 4, 2009 | 03:08 PM
paxtonLT1's Avatar
so whos runing e85
hello im going to be running e85 and whanted to know if anyone had any advice on it. and how you guys like it thanks.
Old Jul 5, 2009 | 03:29 AM
MikeGyver's Avatar
Try searching the forum.
Old Jul 7, 2009 | 06:47 PM
Chevyguy358's Avatar
I run it...works fine uses aprox. 30% more fuel so usually injectors and an adjustable regulator is needed. change the fuel filter after a few hundred miles of converting as it cleans the gunk out of the tank. Only negative is availability and different seasonal blends which contain varying amounts of ethanol, making it a bit harder to dial in.
Here are a few resources:
http://www.hptuners.com/forum/showthread.php?t=9389
http://www.e85mustangs.com/tuning.html
http://www.monodax.com/forums/off-to...85-tuning.html
Old Jul 9, 2009 | 02:02 AM
paxtonLT1's Avatar
nice thanks for your imput what kinda milage are you getting? is power about the same? more? thanks.
Old Jul 10, 2009 | 02:19 AM
I use it b/c my compression is 12:4:1 and I like to run a good amount of timing, i don't actually keep track of my gas milage (sorry). Most who switch over and tune with same combo pick up 5-7% gains, not huge but significant
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
glennxx1
Feb 26, 2004 09:01 AM
aintno6
Jan 26, 2004 10:49 AM
aintno6
Dec 16, 2003 03:53 PM
1984camaroz28
3rd Gen / L98 Engine Tech
12
Jun 2, 2003 08:42 PM
