Finding bearings for KTRE rear end???
Old Jul 3, 2009 | 10:05 PM
blue's Avatar
I need to find wheel bearings and bearings on the inner side of the axle for a KTRE rear end. The wheel bearings that came out have "Green 88128" on the plastic guide for the ball bearings, but I can't find much on Green by searching. The only post I found related is below
Anyone know the part number for the wheel bearings on a KTRE/Moser 12 bolt, bolt in unit for 93-02 F-Body. Has a set of Moser 33? spline axles if I can remember correctly.
Thanks.
Kyle
RW508-er
But RW508-er searches bring up conflicting information; mostly from Ford 9 inch rear end discussions.
Help.
I found all of the parts and it's been back together for a while now. If you're in the situation I was in, send me a message and I can help you.
Old Jul 4, 2009 | 10:21 AM
Check with Mark Williams. They seem to have taken over the KTRE line of 12-bolts, after KTRE scammed all those people out of their money.
http://www.markwilliams.com/rearGMas...CategoryID=157
Old Jul 5, 2009 | 02:46 PM
blue's Avatar
Thanks. I checked the site and they don't have any bearings or seals listed. Maybe if I call they can help, but they probably don't sell them. I've been through this before getting seals and bearings to rebuild my supercharger. I have all the part numbers now except the bearing on the assembly. No one lists all of them. The pinion and side bearings are Timken, the wheel bearings just say RW-990508 ER-1562, the axle seals are Chicago Rawhide, and the pinion seal is National. I'll have to call a few places tomorrow.
Old Jul 5, 2009 | 03:31 PM
mdacton's Avatar
if you got the part number off the thing anyone who sells it should be able to find it...the problem is finding someone knowledgable and thats not easy....
I would start at napa then go to truck driveline shop..... its very simple to measure it and look in the book..... last I heard there are only 3 big bearing manufactures
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
