In-line battery fuse, what size?
Old Aug 16, 2002 | 11:53 PM
$hawn's Avatar
Post In-line battery fuse, what size?
What all determines what size the inline battery fuse is, the power wire gauge size is around 8guage I think, the amp is an MTX Thunder TH2150X and it has two 30 amp fuses.
93 Z28 Patriot Red A4
Old Aug 17, 2002 | 03:37 AM
x7x7's Avatar
Post
add the values of the fuses that are in the amps. you will need a 60A fuse inline.
'96 Firebird Formula M6
Performance
Custom cut-out, Homemade 4" CAI with 9" cone filter, !CAGS, TB Bypass, Manual fan switch, Energy Suspension Trans. Mount, Taylor 8mm Wires, Pro 5.0 shifter, LCAs, Stock 3.42 gears
Stereo
Sony Xplod MP450X MP3 Headunit, Sony XE-90MKII Half DIN EQ, MTX RTX01A Crossover, 2 12" Clarions, powered by 2 Bridged Kenwood KAC-728S amps, Infinity Reference Series component set up front, powered by Kenwood KAC-628, EFX 1 farad cap, 4 gauge wire to cap, 10 gauge to amps
Pic
Old Aug 17, 2002 | 08:51 AM
naztyz28's Avatar
Post
i have the 2300 and was using only a 30amp fuse lol those dont last long also had only 10gauge wire now i have a 60amp and 4 guage all the way to the amp makes a big deference
Old Aug 17, 2002 | 04:34 PM
redz_02's Avatar
Post
The whole point of inline fuses is to protect the wire, not the amp. It is made to trip when the wire is flowing too much which in turn cuases the wire to get extrememly hot and melt the cover off of it. For 8 guage you can go from 40 amp - 80 amp. Depending on the length of the cable. You should be fine with a 50 or 60. I have a 200amp to 2 guage wire into two 4 guages with 100 amps fuses.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Old Aug 17, 2002 | 04:37 PM
redz_02's Avatar
Post
Another good refrence is to look at how much power you running, and look at wiring kits with your power rating and what sized fuses they use.
Soon to be:
HectorM52
Jul 30, 2017 11:46 AM
DSMKilla
Jun 11, 2015 05:02 PM
eanhl2004
Apr 4, 2015 12:01 PM
nosliw
Feb 7, 2015 01:30 PM
