How can i remove these spots??
Old Jan 15, 2003 | 07:11 PM
LT1ponykilla's Avatar
The other day, I was painting something not to far from my car and I got some over spray on it. I then had to get some rubbing compound from Autozone just to remove the paint. By doing that i guess i took off the clear coat or something. I now have smudges that look like fingerprints where i used the rubbing compound. Is there anyway I can buff these out or what should I do?
Old Jan 15, 2003 | 09:15 PM
LtsRace's Avatar
Meguires clay bar system or Mothers both work excellent to take overspray off! I had the same problem, took it right off.
Good Luck!, Joe
Old Jan 16, 2003 | 08:31 AM
MikeLS's Avatar
Smile
I agree that clay should have been your first preference for overspray. Most clays will even indicate that it removes overspray as well as paint contaminants. I'd avoid the Meguiar's clay at all costs, as it's way more hassle than its worth and leaves a mess on the surface, which is NOT supposed to happen with a good clay. Try some Mother's or Clay Magic instead.
But, since you already used the compound now you have another problem to solve. Any time you use a compound it will need to be followed up with a swirl remover or polish to bring back the gloss. The abrasives in a compound will marr and slightly dull the surface. To remove this, you will need some 3M SMR #39009 or Meguiar's #9. Polish it up and it should bring back the gloss and remove the dull compounding spots.
As always use a wax or sealant to protect the area after finishing.
Old Jan 16, 2003 | 12:10 PM
Thanks alot guys. Ill try the mcguires.
Old Jan 16, 2003 | 02:43 PM
LtsRace's Avatar
Let us know how you like it. I agree, the meguires will give you a little hassle if your car is not completely cool and in your garage. It streaks, and leaves a mess, Mothers did work better.
Joe
Old Jan 17, 2003 | 02:38 PM
Mullet's Avatar
I don't know why people mess with Mother's and Meguiar's when Clay Magic ownz them all. Clay Magic is a little tackier and will stick to your hand better. If you drop your clay then its all over for that bar. Time to get a new one. Meguiar's crumbles to quick and Mother's is still a step below Clay Magic in my opinion.
Old Jan 17, 2003 | 06:03 PM
Kevin V 2002 SS's Avatar
Before Zaino came out with a claybar the Clay Maguic was what I used.
A hint while claying, place an old towel on the ground under the area you are working on, just in case you do drop it.
Old Jan 22, 2003 | 10:06 AM
KillerTA's Avatar
Get some less aggressive compound and polish to remove the scratches that the rubbing compound left.
Old Jan 22, 2003 | 10:13 AM
Thanks alot. I still havent gotten around to trying to fix these bad spots yet. Although I was at a friends house and he had some Meguirars #7 that made a little spot look better.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Fastbird93
Jul 11, 2015 04:37 PM
ducttape1975
Jul 10, 2015 06:29 PM
Boss002
Jul 9, 2015 03:33 PM
colts0455
Jul 8, 2015 12:21 AM
