Power Wire
Old Aug 11, 2002 | 10:24 PM
rs91's Avatar
Thumbs up Power Wire
I just bought my camaro and I am getting ready to put my system in. Where is the best place to run the power wire. I haven't had any chance to look real good. If possible, I'd like to get away from drilling.
Old Aug 12, 2002 | 05:19 AM
firebirdude's Avatar
Post
From the battery to under the PCM. Just unbolt the PCM (passenger side, small rectangle box,2 bolts) and slide it out. If you look down in there, you will see a rubber grommit with a few wires going into the car. There is plenty of room to squeeze your power wire through (I have 0awg going through there). It will come out right under the glove box. From there you can run it under the carpet all the way back.
Old Aug 13, 2002 | 09:13 AM
rs91's Avatar
Post
I looked for the PCM. Is it under the a/c stuff on the fire wall. What is the exact location?
Old Aug 13, 2002 | 09:16 AM
97FormulaWS-6's Avatar
Post
The PCM is on the PS, right on top of the back of the inner fender, 1/2 under the windshield overhang. It's held in place by 2 10mm bolts. Remove the bolts, and slide the PCM up, you will see the grommet underneath the PCM on the firewall.
Mike
1997 Formula WS-6, 1 of 473
Mods: P&P MAF, Pro-5.0, SLP LT4 Clutch, 200 Amp Alt, TB Bypass, !AIR, !CAGS, 160 therm, CSI WP, PS Cooler, GMS STB, Cutout, TCI LineLock, ES Swaybar/Trans/TA Bushings, 5%R/20%S Tint, Painted Calipers, Custom Clear Tail Lights/Corners
http://camaroz28.cardomain.com/id/97formulaws6
Old Aug 13, 2002 | 10:04 AM
rthompson's Avatar
Post
I am assuming by his name that he has a 91 Camaro. If the computer is in the same place as it is in the older Camaros it is in the dash, and the power wire is run different than in the current gen F Body. I drilled a hole close to where the wires pass through into the cabin just to the right of where the passenger puts his feet. It might be different onthe 91, but since they are the same generation i am guessing that it is the same as my wife's 84....
Soundillusions.net
The ultimate in caraudio.
Sony, Arc Audio, Infinity, Adire Audio, A/D/S
Old Aug 13, 2002 | 10:49 AM
Post
DOH!!! My mistake...
Sorry..
Mike
Old Aug 13, 2002 | 11:00 AM
ibanez6rg's Avatar
Post
so how do you access the wire from inside the car? do you have to take apart the glovebox assembly underneath?
Old Aug 13, 2002 | 12:09 PM
Lynxis's Avatar
Post
no, just wriggle your a$$ underneath there and look up, you'll see it
$hawn
Aug 17, 2002 04:37 PM
kandied91z
Aug 6, 2002 01:18 AM
zman0069
Aug 2, 2002 02:09 AM
sleeperZ96BT
Jul 24, 2002 11:28 AM
