rings for my 355 kb pistons eagle rods 6psi
Old Jun 18, 2009 | 08:15 PM
paxtonLT1's Avatar
what do you guys think what rings should i go with ? does it matter advantages? disadvantages? thanks for all your help guys you have been great.
Old Jun 24, 2009 | 06:13 PM
paxtonLT1's Avatar
really no one??
Old Jun 24, 2009 | 09:36 PM
blown94's Avatar
heh, see you took my suggestion on the pistons eh? ive yet to get mine in the car and running thanx to my trainee tech at works project instead. when i ordered mine i told them i wanted something like the je hellfire rings, and they suggested mahle firepower rings. they were cheaper and he said they're of the same materials. afterall, theyre mahle, and they dont make crap, so i went with his recommendation. now remember you'll need the 3/64 3/64 5/64 i think it is for those pistons, not the metric ring pack the stock pistons took. good luck with yer build. dont forget you want looser bearing clearances than stock and a slightly wider ring gap. check the spec sheets that come with the pistons. my rings were file fit.
Old Jun 25, 2009 | 06:09 PM
paxtonLT1's Avatar
why looser i thought for fi you wanted tighter?
Old Jun 25, 2009 | 06:35 PM
boosted-lt1's Avatar
NO! A power adder increases cylinder pressure and heat. You run larger gaps to accomdate the increased expansion.
http://www.cppistons.com/LinkClick.a...j8%3D&tabid=75
I built my first engine - but I think from now on I will work with a good engine builder. You may consider the same.
-Scott.
Old Jun 26, 2009 | 05:05 PM
paxtonLT1's Avatar
no there isnt 1 thing i has let some one else do on my car i have done everything to it from the time i got it and sure i ****ed some stuff up in the prosses but thats how you learn + with the money i saved on labor i more then made up for anything i may have broke. me having no money is the best thing that ever hapend to me.
Devinfoote87
Feb 12, 2016 03:21 PM
realistyc
Jul 28, 2015 07:32 PM
Catmaigne
Jul 14, 2015 05:17 PM
mrwz28
Jul 8, 2015 09:11 PM
