Vibration Problems....HELP!!!
Old Jun 18, 2009 | 05:41 PM
93BlackTA's Avatar
I have a bad vibration in my car when i hit 100KM...it vibrates so bad that the passenger seat shakes and you can't look out the back window using the mirror..lol...I have a moser 9in in the rear with 3.89 gears, i have the stock driveshaft, and i have a spoohn adjustable torque arm that mounts to the floor not the tranmission tail housing. I have tried 2 different sets of tires on the rear of the car to eliminate the tires as the culprit. That made no difference.
Please throw any ideas my way as i have about a week to get this ironed out before i go on the dyno for tuning.
Old Jun 21, 2009 | 07:14 PM
93BlackTA's Avatar
ttt
Old Jun 21, 2009 | 09:21 PM
TrybalRage's Avatar
Are you sure it's coming from the rear?
Old Jun 22, 2009 | 04:38 AM
93BlackTA's Avatar
well its from the center console back...and i know its not the rear tire/wheels as i tried another set that were just balanced.
Old Jun 22, 2009 | 05:24 AM
What is the pinion angle set at?
Old Jun 22, 2009 | 05:28 AM
93BlackTA's Avatar
I thought it was set at -2 but i checked it last night and i got 2 different readings....i checked it with just the rear axle jacked up and the front wheels on the ground and when i jacked it up more so i could actually squueze in then i got a different reading...If the pinnion angle was off would this cause a vibration at highway speeds....also seems like the rear suspension is binding when hitting a bump or its aweful tight...
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
Apr 16, 2015 09:57 AM
