10 Bolt Advice Needed
Old Jun 17, 2009 | 03:07 PM
Paul94Z28's Avatar
Hi Board -
Like many on here, I compromised my 10 bolt after a few hard launches. I have a 94Z28 M6 with a 4.10, and rear girdle.
I need to get it back together to last for a few months (no more hard launches).
The following appears to be damaged:
reluctor wheel - a few chips out of teeth, but nothing missing...
Spider gears - top one is missing 5 teeth. Others do not appear to be damaged.
The ring and pinion appear to be fine.
Can I replace the spider gears and baby it for a few hundred miles until I get the new rear?
Old Jun 17, 2009 | 03:19 PM
redneckgames's Avatar
seems alittle odd that the reluctor ring was damaged and the ring and pinion wasnt.
I would double check the ring and pinion first. Then if it does look okay, then yeah I would put another spider gear in it for the time being. You have nothing to lose.
Old Jun 17, 2009 | 03:24 PM
Paul94Z28's Avatar
Reluctor
The reluctor wheels appears to be damaged due to debris floating around and getting jammed between it and the case.
So where do I get a spider gear kit?
Old Jun 17, 2009 | 03:33 PM
at one time you could get replacement spider gears at advance.
or post up on here or check out ebay.
Old Jun 17, 2009 | 03:36 PM
Paul94Z28's Avatar
Appreciate the help - Thanks!
Old Jun 22, 2009 | 09:25 PM
Paul94Z28's Avatar
Got Parts
Ok, I got a used Limited slip unti off another guy on this board. How do I remove the retainer (with the springs in it) that sits in between the gears so I can get the spider gear out?
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
