right side front fender adjustment????
Old Jun 14, 2009 | 01:47 PM
Jachin99's Avatar
There is a giant gap between the skirting and the door on the right side of my car because the fender is sticking way out. How do i adjust that fender? Also my wheels are rubbing the inner skirting in the wheel well on the front and back with the wheel turned. Can i just take the skirting off and it will be fine or what
Old Jun 14, 2009 | 03:16 PM
The plastic fender attaches to the metal bead of the rocker with a couple of screws. If someone attempted to jack the car at that point, the metal bead on the rocker bends and the plastic tabs on the fender break off. Check to see if that is what happened.
As far as the wheels rubbing, that may be a result of the wheels and tires you are running. What is the width and offset of your 18" wheels? What size tire are you running?
RUENUF
Mar 13, 2016 03:39 PM
Patricklt1
Apr 24, 2015 06:29 AM
rocknroler69
Parts Wanted
Mar 22, 2015 04:41 PM
karnykamaro
Feb 2, 2015 01:37 PM
siguy
Nov 27, 2014 10:07 AM
