low coolant light
Old Jun 9, 2009 | 05:44 PM
Dan97Z30th's Avatar
low coolant light
The low coolant light comes on after a few minutes. I check the coolant and it is ok. Has anyone else had this.
Old Jun 9, 2009 | 06:15 PM
moparman's Avatar
Common problem. You can replace it or unplug it. Unplugging it will not set any codes or lights, but you should check the coolant weekly.
Old Jun 9, 2009 | 06:45 PM
A search would indicate that it is extremely common.
http://shbox.com/1/4th_gen_tech2.html#low_coolant_lamp
Old Jun 9, 2009 | 07:13 PM
Dan97Z30th's Avatar
Thanks, for the fast response. That light just drives me nuts.
Old Jun 11, 2009 | 12:17 AM
ROADSEND_Z28's Avatar
Unplug it an no code you say? I did this and have had the code p1661 every since............ I do check my fluid levels often, always have on all my cars but this code may pop up for you.... I have this issue on my 98 SS......
Hugz, Jenn
Old Jun 11, 2009 | 05:30 AM
Hugz, Jenn
The original poster has a 97. In the LT1 cars the coolant level sensor is not connected to the PCM, so there's no way to set a code. Its simply a switch that connects to the light on the dash. Your 98 may be different, but I doubt it.
P1661 indicates a faulty SES light circuit. It has nothing to do with the coolant level switch.
Old Jun 11, 2009 | 07:33 AM
Z28avalanche's Avatar
unplugged mine, it's better than the light on the dash. I check the coolant level about once a week.
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
