Rear brake questions.
Old May 31, 2009 | 08:47 PM
LT1 POWR's Avatar
So my car has 2 brake lines running to the rear, is this normal? The 12 bolt I just installed came with brake lines on it and it has its own splitter built in to accept 1 brake line from the car. I also bought some stainless brake line ends and it also came with a splitter. So I'm wondering if my car is supposed to have two lines going to the rear. Its a 96 the ASR and ABS.
Also the 12 bolt has the sensor on top of the differential. The wires were cut so its not plugged in. Would that cause the ABS INOP light to be on and the ASR to disable on startup?
Old May 31, 2009 | 09:18 PM
hotpart's Avatar
Former Vendor
Yes it is normal. You have traction control which uses 6 hoses and you purchased a rear that does not have traction control. The hose kit you will want is this one. http://www.hotpart.com/shop/index.ph...ct_detail&p=39
Old Jun 1, 2009 | 05:31 AM
https://www.camaroz28.com/forums/sho...d.php?t=688451
Old Jun 1, 2009 | 02:51 PM
LT1 POWR's Avatar
Well, I'd much rather use the brake lines that came with the 12 bolt since the nuts on the stock brake lines are pretty much rounded off. The reason I posted again was because I called up Summit technical support and the said I should only have 1 line going to the rear, they didn't even ask me if my car has traction control when I purchased the stainless brake line ends. Looks like I'll be returning those and getting the correct lines. Thanks.
carguy0119
Apr 11, 2016 11:11 PM
Jlo
Apr 3, 2015 10:32 AM
Jazsun
Dec 29, 2014 12:14 PM
trefidy
Jul 26, 2002 03:40 PM
