what fuel pressure?
Old May 28, 2009 | 07:26 PM
zl1dreams's Avatar
what fuel pressure?
hey guys i got my fuel pressure gauge today and i just want tknow what i should set my fuel pressure at. my mods are in my sig.
and to check my pressure, i have to remove the vacuum line from the regulator then start her up right? thanks guys
Old May 28, 2009 | 10:04 PM
MikeGyver's Avatar
Hmm. it's either 43.5 psi or 58 psi (3 or 4 bar)
Old May 28, 2009 | 11:27 PM
jsetzer's Avatar
43.5 is stock... Have no idea how much power or boost you are planning. 1 racetronix pump will imho get you to 450-500 rwhp at 43.5 psi... it just won't be enough volume for more no matter what pressure its at.
I am running 2 x 255 pumps, stock lines and rails, 60# injectors, 60psi with a 1:1 referenced regulator.
Old May 29, 2009 | 01:11 PM
zl1dreams's Avatar
i will be installing my dual 255 pump setup this weekend. i also have #60 injectors and aeromtovie AFPR thats 1:1 with boost and stock lines. i should be running in the 13-15# of boost area, hoping to put down 650rwhp.
so i should set me fuel pressure to 60psi as well. this is with the car idoling and the vacuum line taken off the AFPR right?
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
