z06 wheels on 2001 Z
Old May 28, 2009 | 10:46 AM
z28rp's Avatar
im looking to get some new style Z06 wheels (2006) and i need some advice. i want 17'' rims in the front and 18'' in the back with 245 40 17 and 275 35 18 tires. will this affect my speedometer at all? also is there anything else i should know before i get they?
also should i go with the 275 35 18 tires in the back or the 275 40 18?
btw i currently have the stock 16's
Old May 28, 2009 | 11:41 AM
Joe Bellman's Avatar
search corvetteforum.com and you will probably find a set of OEM Z06 wheels for a decent price. They will be 17 in the front (265/40-17 ), 18 in the rear (295/35-18) but will fit fine (once part of the rear bump stop is removed) It didn't affect my speedometer.
Old May 28, 2009 | 12:06 PM
z28rp's Avatar
i already found the rims i want for the price i want to pay but, 265 and 295 are too wide for me, my ls1 doesnt have that much power
Old May 28, 2009 | 09:31 PM
z28rp's Avatar
the rim i want are 17'' x 9.5'' and 18'' x 10.5
will 245mm tires fit on the front and will 275mm fit on the back?
Old May 29, 2009 | 04:50 AM
they will looked stretched if you get them on there. the OEM Z06 rims are those widths and run sizes i posted above.
Old May 29, 2009 | 08:13 PM
You want to match the STOCK tire diameters. Did your car come with the 235/55-16's (26.1") or the 245/50-16 Z-rated tires (25.7")? That will determine what size tires you need to avoid recalibrating the speedometer. Recalibrating no big deal, just a minor PCM tweek.
A 245/40-17 is way too small at 24.7". You would want a 245/45-17 at 25.7" or a 255/45-17 at 26.0". But the 245/45-17 size tire is typically not recommended on a wheel more than 9.0" wide. That leaves you with the 255/45-17 which fits on wheels up to 9.5" wide.
A 265/40-17 (25.3") and also a bit too small in diameter. The next step up would be the 275/40-17 at 25.7".
In the back, 275/35-18 is a bit small at 25.6", and OK for a max wheel width of 11.0". A better choice would be a 285/35-18 at 25.8". The 305/30-18 at 25.2" is also too small a diameter. The 295/35-18 is 26.1" and would work.
Old Jun 2, 2009 | 11:49 AM
z28rp's Avatar
ok im buyig a set of used z06 wheels soon, and they come with tires that need to be replaced, but ill put them onfirst to see how it looks and test the speedo. thanks for the help. btw my stock wheels are 245 50 16
Old Jun 3, 2009 | 10:22 AM
z28rp's Avatar
will the 275 rear tires have enough clearence in the wheel well? just by eye balling it, it looks like they'll barely fit. i know the ss has 275 tires and i just need to know if the 275's will fit my z
Old Jun 3, 2009 | 02:43 PM
deerslayinrenek's Avatar
I just put C6 Z06 replicas on mine fronts are 17x9.5 with 275/40/17's and the rears are 18x10.5 with 315/30/18. My rear wheels have 58mm backspacing and cleared ok, I added just a little more clearance to give me some added comfort, but i dont think it was necessary. Heres a pic but it's from a camera phone on a rainy day so it's not the greatest.
Old Jun 3, 2009 | 08:24 PM
z28rp's Avatar
i dont care much for the c6 zo6 wheels but wow those look good, i decided to go with 275 45 18 and 245 45 17 i dont want the tires to be wider than that my ls1 doesnt make that much power.
Old Jun 3, 2009 | 10:57 PM
I don't have much power either but the 315's sure do look good on the rear lol..........the 275's will still look good and be much cheaper. when my 315's wear out I'll drop down to a 295 or 305 unless I find another good deal like I did on my Pirelli's.......Good Luck with whichever you decide
Old Jun 3, 2009 | 11:36 PM
Why would you pick a 275/45-18? That's almost a 28" diameter tire. Will just fit in the wheel openings, and will raise the back end of your car about 1" higher than stock. Its going to have a "rake" like my Formula has with 28" slicks in the back, and 26" skinnies in the front:
http://www.injuneer.com/images/photos/DCP03466.jpg
Old Jun 4, 2009 | 08:42 AM
z28rp's Avatar
that was a typo i meant to put 275 40 18
they are about 26.4'' in diameter so they are about 3/4'' more in diameter than stock, your right about 275 45 18 being to big.
Strick
May 26, 2015 11:41 AM
Boss002
May 20, 2015 12:55 PM
WildRidez
Feb 23, 2015 07:24 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
hotrodyou1
Dec 20, 2014 10:05 PM
