gear swap
Old Jan 14, 2003 | 09:19 AM
2002 3.8's Avatar
gear swap
how much will a gear swap cost me, installation and everything, and is it really worth it. to 3.73?
-jonathan-
Old Jan 15, 2003 | 02:49 AM
Silver00's Avatar
where in tx are you? I may be able to send you in the right direction depending on u'r location.
Silver00
Old Jan 15, 2003 | 03:05 PM
Bliggida's Avatar
3.73's will feel the same as if you added 31 horsepower.
Assuming you go with a name brand, like Richmond, or Strange. A Ring and Pinion gear set along with an installation kit for it, will cost about $300 total.
Installation by a professional shop will cost about the same. So if you aren't stepping up to a posi differential, then it should cost around 600 dollars.
Zee man
Feb 12, 2015 07:07 AM
rocketman051894
Jan 30, 2015 03:23 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
