Does nitrous...
Old May 25, 2009 | 05:22 PM
99_Z28's Avatar
Does nitrous...
Does nitrous clean the motor out, I sprayed a half bottle threw it and it seems to run smoother now? The car loves the stuff...
Old May 25, 2009 | 08:28 PM
slowride94z's Avatar
Oh yea it will clean out a lot of crud, piston rings, ring lands, valves, and rods sometimes
Old May 25, 2009 | 11:33 PM
Z-RATED94's Avatar
LOL ,I guess it would if not set up right. On the other hand, after spraying my first couple of times, the next time out on motor I ran my best ever NA pass. Could have been better air, but I think the nitrous cleaning had something to do with it also.
Old May 26, 2009 | 12:04 AM
N2O does not break down into nitrogen and oxygen until it reaches about 600*F, so its unlikely that it would affect anything up to and including the intake valve. Its sure going to clean your plugs off if you have a "too hot" plug... but that might include removing the ground strap as well.
Shell is currently advertising "nitogen fortified" gasoline. How would a gas that doesn't burn "fortify" gasoline? When you check into what they are actually selling, its a nitrogen-based detergent compound (additive) that is supposed to clean the valves..... misleading advertising at best.
Old May 26, 2009 | 06:42 AM
99_Z28's Avatar
Thats what im saying, it seems to have more power n/a now?
haha
I didnt take any short cuts, so it should be safe right ? FPSS, pulled -3 of timing, a/f ratio is at 11.8-12.0 tr6 @.036 and I only run 93 octane. Im more worried about the glass tranny taking a dump...
Interesting....
ULOOSE
Jan 29, 2008 07:52 PM
C Man
12
Nov 7, 2007 08:23 AM
93BlackTA
N2O Tech
Sep 16, 2007 09:11 AM
LT1-TA
N2O Tech
Feb 24, 2007 02:45 PM
