Rear brakes to tight?
Old May 21, 2009 | 08:15 AM
95ltslow's Avatar
This is my first brake job on the z.Heres what I did:
-Took the cap off the brake master cylinder
-pulled the caliper off took the old brakes out
-installed the new rotors
-Installed the new brake pads with the backing plate and that little H clip that connects the two pads and installed them in the caliper after depressing it.
- Mounted the caliper back on and slid the pads over the rotor. It goes on but It is really tight. I was under the impression that the rotor should still turn freely and not contact the pads unless the brake pedal is pressed. It is a little hard to turn. Is that normal for it to be so tight?
Old May 21, 2009 | 05:16 PM
Did you compress the piston into the caliper, before completely removing the pads?
Old May 21, 2009 | 11:22 PM
95ltslow's Avatar
^Yes. I used the pad to push the piston back into the caliper.Then took it off and put the new pads in.
Old May 22, 2009 | 06:53 AM
There will always be a little contact.
carguy0119
Apr 11, 2016 11:11 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Jlo
Apr 3, 2015 10:32 AM
Jazsun
Dec 29, 2014 12:14 PM
