4l60e help
Old May 17, 2009 | 09:56 PM
wrecker_man's Avatar
4l60e help
ok will a tranny out of a 95 3.4 fit in a 93 5.7 ? if not does anyone know where i can get the 4L60E for the 5.7 fairly cheap for now
Old May 17, 2009 | 10:31 PM
12SCNDZ's Avatar
3.4 and 5.7 have different bellhousings that won't physically bolt up. Not to mention the fact that the '93 is a 4L60 (non electronic) transmission. The bad news is, a '93 F-Body uses a very unique 4L60. Only a '93 unit will work in your car.
Frank
CPT
Old May 18, 2009 | 11:11 AM
ok if thats the case how hard would be to just convert the car over to either a 350 turbo or a 700r4 ?
Old May 18, 2009 | 07:26 PM
LearJet's Avatar
A 4L60 is a 700R4
Old May 19, 2009 | 07:22 AM
12SCNDZ's Avatar
Yes, technically a 4L60 is SIMILAR to a 700R4, but not the same. The 4L60 for your '93 uses a 5 pin, round case plug. All other 700's use a 4 pin (maximum), square plug. The '93 4L60 has an extra switch on the valve body. The transmission uses a different valve body, separator plate, wiring, and reverse imput housing.
Be aware that a 700 will work without throwing a code for lock-up. If you don't hook up the lock-up, you'll burn the 3-4 clutches up.
Frank
CPT
Old May 19, 2009 | 08:46 PM
ok im a dumba** when it comes to an automatic tranny. i'd take a manual over an automatic any day. put that in dummy terms for me frank! are you saying if i change the plug it would make the lock up work ? I dont have the cash to get it built how i won't it right now and won't until i re-enlist or until tax time. whichever comes first. Around here they are trying to sale used 4l60e's for 8-900 bucks. i got a 700r4 sitting back home in sc with the wiring harness to boot. i wuld appreciate if you could explain how to make it work if its possible
Old May 20, 2009 | 06:15 AM
12SCNDZ's Avatar
If you have some knowledge of wiring, I can walk you through it. I'll try to shoot you a PM later.
Frank
CPT
Old May 20, 2009 | 11:03 AM
alright thanks frank yea i know some about wiring.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
