line lock not holding car in burnout
Old May 17, 2009 | 08:47 PM
budgetlt1's Avatar
my linelock will not hold my car during burnout, if i have street tires its ok but w/my et streets it starts to roll after about 1 second. i am unable to get these tires hot as a result and have had a best 60 ft time of 2.065. i have double checked for any air in the lines and there is none. help?
Old May 17, 2009 | 11:53 PM
What line lock do you have? I have a Hurst and completely stock (and original) front brakes, and it will hold against a 6,000rpm 2nd gear burnout with 28" ET Drags.
Where in the system do you have the solenoid located?
Old May 18, 2009 | 03:45 PM
97FormulaWS-6's Avatar
Might not be getting enough pressure built up to hold the calipers; r u pressing as hard as possible b4 u set it?
Old May 20, 2009 | 09:20 PM
87Aerocoupe's Avatar
I always pump my brakes then hold the pedal down and set the lineloc then take my foot off the brake and I never have any problems.
Old May 30, 2009 | 11:42 AM
budgetlt1's Avatar
thanks, i got it worked out-i was rolling into the burnout too slow. i never had a problem before (running street tires) last night i would just nail it through 1st and 2nd and made some nice smoke
Old May 30, 2009 | 04:49 PM
mdacton's Avatar
whenever you start your burnout start at max throttle......
you can always let out some, bit when the tires start to bite and you get back on it its going to push or go sideways
CARiD
Dec 26, 2014 04:20 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
